Ok...here is my challenge. We put the 97 XP in the water for the first run of the year, and she would run about 35 to 40 mph and then shut off...gauges would jump and hop around too.
just hit the start button and she would quickly fire right back up and run for another couple hundred yards.
We have been trying EVERYTHING...and now she has also gotten a lot worse too...will crank up on the trailer, run for 5 seconds...then shut off just like you hit the kill button.
My buddy has a 97 xp with this same exact problem too!!
here is what we have switched out...and still have the same problem.
Carbs.
Start switch.
hood with the other wiring harness.
Black coil box.
key post.
rectifier.
MPEM.
whole front motor cover.
What else is there...? Is there a crank sensor or something? I am really starting to think it is the motor...and not the wiring.
Our next step (unless someone on here can give me ideas) is to pull the engine out and see if it will run in another ski....
And I really dont want to do this. !
Carbs.
Start switch.
Black coil box.
key post.
rectifier.
MPEM.
