So I just bought this MY XP this year, and I got it pretty cheap as a "project" I got it running but its not running right. If you hold a constant throttle, such as at half throttle it speeds up and then bogs down. and it continues through a cycle like that, sometimes it will run good for 15 seconds before it bogs down again, sometimes it will only last a second. It seems like it is having a hard time getting fuel, or my dad said it was like it was running on one cylinder, and sometimes the other one would hook up. Any ideas?
Next problem is the VTS doesn't work, something around the motor clicks when you push the button one way, I think it is down, but it doesn't move in either direction.
Also the gas gauge and speedo do not work, where should I check for bad connections?
