Hi forum.
Found myself here whilst searching online for a resolution to my problem.
Hopefully somebody here can help out and explain things simply for a newbie.
Here goes..
I have a 1997 Seadoo xp.
Originally had a seperate issue that I was battling, but after a year or so tucked away, I've now pulled it out to find another problem has reared its ugly head.
- When I put the DESS key on the post, I get no beeps. Normally I would get 2 short beeps, but now nothing, and the engine won't even try to crank when I press the Start/Stop button.
- I can still adjust the VTS, just no beeps or starting power.
- Battery is fully charged.
- From what I can find online, the common advice is to check continuity/resistance at the DESS post, and at the Start/Stop switch. But how? I have the wiring diagram so I know what wires are what, but where is the easiest place to test? I can't seem to dismantle the handle bar assembly.. Can I test from the plug that joins to the MPEM?
Please help! Apologies, you may need to draw some diagrams in crayon for me to understand
Here goes..
