hexec
First of all, I just purchased this ski and I'm fairly new to PWC's, so please be easy with me. Took it out today for the first time and found it to be very unstable and I tipped it over. I flipped it back over fairly easily but I could not get back on without it tipping again. I found that the hull was flooded with water. I figured that it was so unstable due to the water in the hull. Pulled it out of the lake to drain it and put it right back into the lake. With the engine idling I monitored the water level in the hull. It was dry. Ran it full out for a bit and it was still dry. I did a slow speed donut and it flipped over again. This ski seems to want to be in full motion to stay upright. Anyway, flipped the ski back and found that the hull was full of water again. I noticed that the engine was still running while the ski was capsized then it cut out. I'm pretty sure the key was pulled out almost immediately. My question is how does the hull fill up with so much water so fast? The back panel seal has a 3" section that is detached from the body, but there is no way that much water gets in through that space. Next I was thinking that the engine is drawing mass amounts of water into the hull while its capsized. Is it possible that the engine is drawing the water in through the submerged air vents?
I understand that this model is tippie and takes some skill to prevent capsizing. I'm ok with that. I will eventually learn to keep the damn thing for flipping over. What I'm not ok with is the hull filling with water which makes it impossible to reboard without tipping again because of the weight of the water. I cannot deal with having to be toed out every time I capsize.
Any help would be appreciated. What could be causing this condition?
