All I can say is WTF!!! I just rebuilt the carbs last week. Started it up and it ran fine. I took it out the day after I bolted the carbs back up and it was hauling ass like a brand new ski. Here I am a week later trading the Old HX for a for a jet boat with no engine and the b**** wont idle. It will idle fine if I give it gas through my primer kit. About a pump a second
. And it will run fine when I give it anything over 1/4 throttle on its own. When I let off the throttle it runs for a second or 2 then stalls out on me. I have tried messing with the idle and the low speed adjustment. (Stock is 1 3/4) I guess I am going to be pulling the Mag carb off and checking the fuel pump and carb filter. I doubt I will find that they are clogged because the carb doesnt even have a gallon of gas through it. The pop off psi was around 50 psi right on spec when I had them apart last week. Both plugs are wet when I check them after it stalls so I am thinking it is getting fuel but not spark at idle. I trimmed the plug wires again just to be safe. Should I check the engine for a pulse/ vac at turnover rpm's? I printed out the manual from sdf but I am not sure how I should test for spark? Do these ski's have coils or just a stator? Any input would be greatly appreciated since I will be stepping up to a boat to bug you guys even more. Especially Timmy (and yes Tim that hole loved the JB weld
