digital sol
I rebuilt my carbs this morning both are popping off at 29. low at 1 turn out, high at zero there's a lot of conflicting info on pop off out there does this sound right to you guys. Getting ready to start on putting everything back on the engine, should I reuse my intake gasket and use copper rtv on the mag housing or order some new ones.
I am not an expert but going through this myself and everything I read said to try and target the 32 range and keep them +/- 1-2psi within each other. I am finding conflicting info on the high and low speed settings on various web pages though . What source are you referencing for the high and low settings?
At 29 you are very close you can bend the arm slightly down and get to 32. (do not bend the arm down more than 1mm past level with the carb body)
I just rebuilt mine and ended up at 32psi but my guage might add another 1-2 psi so maybe 34 but it should be perfectly fine from everything I read & its way better than what they were before the rebuild lol!
