cmartin248
Okay, I have a matching pair of 97 GTX's and one of them is giving me a fit. The engine runs fairly well at mid rpm's, but coming out of the hole or WOT, it is very weak and surges. Sometimes it feels great for a few seconds and then dies back to 40 mph at WOT.
I have; changed the fuel lines, cleaned the carbs and filters several times, and the small carb filters, cleaned the RAVE's, tried the red wire from the rectifier, 130 psig on each cylinder, checked the pump and bearings, good stream of fuel to the carbs, makes it run worse if you slightly pull the choke, new plugs, and new plugs again, slow needle at 1.25 and high at 0.0.
Help,, thought I was a mechanic....
Thanks for any advice......
