This weekend I was out on the water and ended up getting water in the motor. I didn't notice one of the drain plugs came undone. I jumped on and cranked it over a few times then nothing. I jumped off and noticed it sitting low and found the plug out. We pulled it out of the water and still nothing. I put the key on and it beeped but the starter relay clicks once and thats it. We pulled the plugs and my buddy touched the two relay posts and it started cranking over pushing water out of the spark plug holes. We did that about 10 times off and on making sure not to over heat the starter. I have swapped out spark plugs added a little oil the the cylinders so they didn't rust. It has spark and fuel. It will only turn over with the plugs out and will not turn over from the start button. Can someone give me an idea what to try next? Thank you for your help.
