daboostcreep
I finally got my ski running right, or so I thought...then burned the rear piston.
Here's the skinny:
96XP bored .50 over (found out after pulling head when cylinder lost compression)
Rebuilt carbs jetted to Factory Pipes recommendation 150 Mag, and 152.5 PTO with stock pilot.
Uni filter clamp on filters with billet adapters.
I set the carbs to Factory Pipe's specs.
The ski was hard to start, and would bog in midrange, then run good at higher RPM.
I run a mix of 100, and 91. Equates to 93 octane.
Here are my questions.
I want good reliable performance. This is a disaster, and nedless to say, I'm pissed and don't want to repeat this mistake again.
Here's the skinny:
- With the cylinders being bored .50 over and not knowing it, did that cause an issue with jetting? Do you need bigger jets because of the bore?
- Should I have run, or run in the future the stock airbox?
- Should I remove and sell the factory pipe and go back to stock exhaust, or stock exhaust with a shaved head?
