Not sure what to say about the tach.If those TTO tachs are better I need to get one. On the VTS, yes, I think that is what he meant.
On the rebuild, you get to pick from Pro-x, Wiseco or OEM pistons and for the crankshaft connecting rods: pick from Hotrod, Wiseco or OEM. I will check compression...do you know what it should be?
The water regulator I got from Nick@westsidepowersports and is working great. The original one was leaking badly.
IIRC?
So the high performed build is just your choice of parts, no upgrade in actual HP.
Compression should be 150.
Good to hear about the regulator, rules that out.
IIRC:
If I Remember Correctly
