Brprxt215
Hey guys I got the flywheel issue solved on my XP and it’s running good.so went out on Halloween and picked up a winter project(or so I thought) driveshaft spun by hand so I picked it up for $300 with a trailer. Put my agm battery in and it cranked over good. Tested compression it’s 148 on both holes. Spark checked and has no spark. Today I went out with a volt meter and did a bunch of ohm test on the stator, relay, battery, solenoid, and coil. Everything tested good except the coil. When I pulled the female connectors off the coil and did an ohm reading the manual says between .3-.6 ohm. I was getting .0( I did have the stator plug unplugged not sure if that matters) when I plugged the stator plug back in it I was getting 3.9 ohms. Not sure if I should just replace the coil or if maybe the grounds are corroded not letting it spark. I’m going to try and clean the grounds in the morning but just looking for what you guys would think would cause no spark or any other way to test the coil.Thanks in advance
