griffith1230
Hello Friends:
Let me start by saying that I am new to Seadoo Forum. I would appreciate any help you all can give me as a novice.
I purchased a 1996 Sea-Doo XP with a 787 from a family member. Turns out it had major issues. Last year, we realized it needed a new engine and bought one from SBT in Florida. While putting it in, we must have tightened the oil pump a bit too tight and caused a hairline crack to appear in one of the "ears" on the pump. New fuel lines were in throughout, new starter, new battery.
Took it to the lake for a spin. At first, it did great, but I noticed a problem a bit on take-off. I am not sure if this is what you all describe as "cavitation." As I rode it through the week it became progressively worse. RPM would jump right off, but the ski would sit still with no takeoff for several seconds. Finally, it was like someone would take their foot off the clutch and it would go.
I spoke to SBT's tech and he suggested that this may be a problem with the wear ring. Do you agree?
Second, when I was at top RPM's, I noticed a high pitch squeal. It got progressively worse on the last of five days at the lake. By the final day, It was squealing almost the entire time the throttle was engaged.
Could this be related to the fuel pump failing? I am inclined to spend $15 to block off and just mix the oil/gas myself.
I am a family man with limited funds and cannot afford to take to the dealer. I have spent too much to turn back now. Please help!
Jacob
Temple, GA
Jacob
Temple, GA
