cuspeedster
My problem is that while running on open water my speedster just cut off. Here is some background to this.
Being from florida I did not winterize my speedster over the winter which now resides in south carolina where it did free during the winter. It was on a trailer and covered by the cover and a tarp. After winter I tried starting and got it to crank over but then tried again and apparently it had old gas so it wouldn't even crank. I got all the old gas siphoned out and put about 5 gallons of new premium fuel in. Within a few cranks both engines fired up while still on the trailer. I then took the boat out on the lake and idle was fine, then cruised at around 30mph for a short bit before taking it back up to around 50mph so about 5-10 minutes. I then took a sharp 180 degree turn similar to how we'd do 180s/360s but didnt cut it quite hard enough to pull that off. So right after I got out of the turn both engines shut off. All electronics still worked such as the blower, DESS, and bilge. I tired to start the engines back up but they would crank over and immediately shut back off before I could even give it some gas or rev it at all. After sitting dead in the water for about 5 minutes and periodically trying to restart they finally both kicked back on as if nothing was wrong. I cruised back to the ramp at around 30 just fine and sat and idled waiting for the ramp for another 10 minutes without a problem.
Does anybody know what this could be? Before I take it out next time I'm going to throw some sea foam in the gas tank incase there was any moisture in there. I'm going take it out again in a couple days with a friend of mine riding along side incase the problem persists. If any of you have an idea or maybe some other trouble shooting tips they'd be appreciated since I'd prefer to not look like a fool if this happens again when I have people with me on the boat.
