HughJorgan
Hi!
I have a 96 GT that says GTX on the sticker on the side. I put a new battery in it, and it is properly charged. When I put the ignition kill switch on, it does the beep beep as it should, but when I push the start stop switch, the starter doesn't even click. I checked the 6 fuses at the front, and they all tested OK. I am not much of a mechanic, but do have good technical skills if that makes any sense. I put a volt meter on the battery, and the voltage (just under 13 volts) does not change when I push the start button. Any suggestions on what to try next?
Thanks!
Thanks!
