Yeehaa Mo'fo's :hurray::hurray::hurray:
Im now excited:rofl:
Before introducing spark, i degreased again, and sprayed water dispersant, and checked wiring etc,
I did find a few blind electrical plugs in the bottom of the hull, all were refitted, and i also opened the iggnition box and found 2 wires unplugged, i then found another connector unplugges near the mpem.
I then opened up the mpem box to check fuses and all was good.
By now everything was dryso i proceeded to fit the battery then pressed the start button 5 times, heard no beeps but the VTS worked like a charm, i just need to replace the tie-rod to the nozzle.
Then i put a magnet on the DESS post (i read this somewhere) and the guages lit up and the mode and set buttons worked, but still no beeps.
Then i pressed start again and got an all mighty beep that beeped for ages, like 30 seconds to a minute and nothing i did stopped it
Then i pressed start and it beeped until i pressed start again and it stopped??
Now every time i press start it beeps for ages?????
From my guess work,,,,
I have now confirmed;
The engine to be free, with no sticking points etc,
The VTS system to be fine,
The info center guage to be working, (although water damages i think)
And the MPEM to be working? (or i wouldnt have power)
Now to get a key programmed, should do this in the next few days, however im happy thus far, does everything seem kosher to you guys so far???
I am a member of a fishing and boating forum in aus called Fishnet.com.au and this forum with premiem membership and acess to manuals etc leaves it for dead, a great credit to all those that make it possible.
Cheers :cheers:
