I've been working on a 1996 SeaDoo Challenger with a 787 Rotax and I can't get the top speed above about 33mph on smooth water. Top engine speed of 6,000RPMs*
Things I've done:
- replaced wear ring
- trimmed spark plugs wires
- cleaned rave valves
- rebuilt exhaust rave valve
- rebuilt carburetor
Losing my mind. Not sure where to go from here. Compression was roughly 130psi on both cylinders but I've read that a lot of guages aren't very accurate so the actual pressure might be different. The cylinders were giving identical readings though.
It's been getting a little bit better with each fix. Carb rebuild was the latest thing. It runs smoothly now but I just can't seem to get the top speed up. I've read that most people with this boat usually have RPMs higher than 6k at WOT. Any ideas would be appreciated.
Things I've done:
