Hi all, I'm having an issue with my new to me boat. My engines are not running togather past half throttle. As I power up both engines run in sync until around 4500 rpm or half throttle but as I go past that to get on plane, my port engine then accelerates faster than my starboard. At full throttle the port engine hits about 7200 rpm and the starboard about 6800. Any ideas? I just finished cleaning out the carbs and everything looked good inside but all the high and low speed screws were set to different positions, my high speed screws were set anywhere from 1/4 to 3/4 out and my low speed were anywhere from 1 1/2 to 2 turns out. I reset them back to where the service manual stated. Unfortunatly I didn't have the boat on the water last year so I can't tell you if things are better or worse. In all honesty I would like to slow the one engine down if possible, 55 mph accross the water is a little too fast for me.
THX
THX
