Age and cavitation....
This is a sign of slight cavitation. Its really not unusual, especially for a ski almost 15 years old.
If your getting the speeds you say, then your wearing ring is probably o.k. When the wearing ring is shot, your motor is running but the ski isn't going anywhere. As the ring begins to wear, you begin to lose RPM.
If your stator vanes are knicked or your impeller has a few dings in it, this is the most often cause of what your feeling in the acceleration. When you make a sharp turn, it'll likely do it there too.
The dings and small knicks cause the water to flow with a bit of turbulence. This is where you pick up slight cavitation. Personally, I would not worry about it until it gets worse.
I would consider popping off the nozzle and bucket to check your pump oil. If you have no idea when it's been maintained, I would be doing this ASAP. This is the quickest way to kill your pump.........You can use the search engine to find info on it. Use keywords like pump oil, changing pump oil, impeller removal........:cheers:
