My 95 GTX ran good when I first got it, then would not start/run, no fuel to carb, pulled carbs rebuilt, internal filters full of stuff, ran good on trailer, first time out after rebuild, ran good, 1 1/2 hour ride, put on trailer, flush, Saltwater. Got new spark plugs, had BR7ES in it, book called for BR8ES, I bought what the book called for, replace plugs, back trailer into water, start, fires and shuts down, finally get it started, will not clear out. Start checking, mag plug dry, pto plug wet, bought new set of BR7ES plugs and put in, runs better but just does not sound right, no more riding. I have pulled carbs, verified jets are correct, 75 pilot, 132.5 main, today tested pop off pressure, pto carb pops at 10 psi, mag pops at 38 psi. I now have to get springs and test to get pop off balanced. Then maybe it will run right, there is a missfire or uneven firing as it is, hope balancing pop off pressure will fix.
Then I will tackle the 96 GTX, starts, idles good, get away from dock, start to open throttle, does not want to go, loading up, as the engine warms up it starts to run good and will run good til cold again, this is before and after rebuild. I have a wet plug and a dry plug on it as well, mag, wet, pto, dry. I feel that I will find similar problem on the 96.
At the time of rebuild I did not have a way to test pop off, I now have that, so carbs will come off of 96 again for testing. Any other suggestions are welcome, these carbs are definitely different from automotive so I am open to suggestions. Thanks in advance for any help provided.
Had I found this forum before I did the work I would have done it all at that time, I just did not understand some things about these carbs that I now do understand from reading this forum, great information here.
