94 xp pop off setting ultra rare spring
Jakeo625
So here's my issue is rebuilt the carbs with osd back to oem followed the rebuild thread to a t. They specify to resue old spring no big deal. Did leak check and all tests pass except pop off. My issues is the spring which I determined by swapping faulty spring and low pressure followed. The oem spec is 16-21 psi for the 94 Xp I'm at 23 psi on one carb and 12 on the other. The spring is about as rare as unicorn horns part number 270500242 the lowest spring 65lb mikuni with my 1.5 needle and seat would give me 30ish pounds on pop off what do I do? Am I just completely screwed or what I have way to much invested in this jetski to let a $3 spring be the end please help
So if I swap to 2.0 needle and seats and black springs do I need to change any other aspect of the jetting? Or is the pop off pressure all that matters? It seems so easy looking at it now i appreciate the info plus the manual definitely will come in handy.
So along with the question of whether i need to change other jetting aspects when switch to the 2.0 seat is there a difference in needles? My 1.5 needles have never been ran and I can save about $10 buy just 2.0 seats. I know the seat orifice is different but are the needles also?
To add to this I did some deep diving on the forum last night and found this thread where mikidymac says I shouldn't change the needle and seat to a larger size. So I'm at a loss here how do I get the correct pop off 16-21 when the unicorn horn spring is non existent? Using even 65 gram springs according to the chart would get me around 32psi which is way higher than what is specified.
