andy.262
So I had another thread about this issue here 94 XP idles but won't rev but I kind of got derailed talking about ultrasonic cleaners....
So to recap - its a new-to-me 94 XP, it will start and idle, but give it any throttle and it will die immediately. While its idling it is shaking a bit more than I think it probably should be.
I have done so far:
- verified strong spark both sides
- compression check (140psi each)
- new fuel selector, fuel lines, water separator + o-ring
- rebuilt carbs using correct OEM Mikuni kits from OSD with new needles and seats, verified pop-off is correct, the same for both carbs, and not leaking
- carbs are in sync as best I can tell
- verified rotary valve timing (149 deg open, 65 deg closed according to manual)
- verified rotary valve gap according to manual (feeler gauge between rotary valve and cover)
- as a test, bypassed entire fuel system to run directly from a fuel can into the carbs
What am I missing here? What else could this possibly be? There's not supposed to be an accelerator pump on these carbs, right?
I have done so far:
