Hey guys- First time posting, need some expert advice.
I have a 94 xp. Recently while on the water, she died at full throttle. Was unable to get it restarted. Starter was unable to turn.
Once ashore and cooled down, was able to get started. I am concerned engine was running lean and pulled ski from the water.
At home, started looking for cause of lean condition, found a crack/hole in the pulse line, from engine block to carbs.
Checked psi, 150 in piston near front of the ski, 120 at rear
If the hole in the pulse line was the cause of the lean condition, and has been corrected, can this sea doo be driven for the rest of summer?
I know a winter top end rebuild is in order.
If the ski cannot be driven, how do I determine what size top end rebuild kit to order? this engine went through a full rebuild 2 years ago.
thank you for your help!
