luckysaturn13
My cooling system indicator outlet isnt spraying any water out. I disconnected the small hose from the fitting on back of hull and pushed a small wire thew the plastic fitting to check for clogging. It was fine. I ran it wtih hose not connected to plastic fitting on the backthe hull and nothing. i blew threw the hose towards the fitting in the head and its not clogged. I also took that fitting off to check just in case. I know its moving water threw because my exhaust is staying cool to the touch when running in the water. Does it have to be at more than an idle to spray water out the csi? maybe thats my problem? its not over heating and buzzers not going off. I ran a half tank of gas threw it today in the river.I just verified buzzer does buzz. Im thinking my temp sensor is ok but i guess it could possiably be bad? ill test it later but im pretty sure its not overheating. any help is appericated.
thanks!
thanks!
