mdaugherty
I recently bought a used '94 sea doo spi. It wouldn't start when I bought it had the starter checked and rebuilt. Took it out the first time last week and it ran great for about an hour. Then the sea doo started surging and would cut out after just a short time of running above idle. The oil level light(I think) red light above gas gauge came on. took the seat off and checked and one of the oil hoses had come loose and all the oil drained into the hull. replaced the line put a new hose clamp on and refilled the oil tank. Sea doo will still not run. At this time I drained the fuel tank cleaned the carb changed the plugs and pulled the heads. Cylinder walls and pistons appear fine carb was a little dirty but not to bad, clean now. When plugs are out of head I cannot hold my thumb over hole when cranked I don't have an actual compression gauge. Also put plug in boot and hold to head it does spark. The oil light still come on everytime I hit the starter, is there a reset button? I have disconnected the battery to see if it would reset the light with no benefit. Any help for a newby would be greatly appreciated.
p.s. The '96 gts I bought with the spi runs great!!!
