Venturi Q's
I am having the same issue on my 98 GTI so I will check the seal as well even though it does not take on water while sitting idle. I have a question about the venturi (not sure if that is the correct name) I just replaced the wear ring, impeller in great shape w/ proper clearance and noticed the edges of the venturi, next to the impeller, had chips broken away, 1/4" to 1/2" and some of the remaining edages were bent a little sideways 1/8" or so. Can these damaged venturi blades cause cavitation behind the impeller as well? This is really bad when my wife and I try to take off and it does nothing but cavitate.
