93 gtx carb removal
olilt
I need to rebuild the dual carbs on my 93 GTX, type 587 engine. I have removed the intake and flame arrestor assemblies and can look directly at the carbs. I am stuck as to how to proceed further. The flange bolts where the carb mounts to the intake manifold appear to be unreachable with a conventional wrench or socket.
The manual I am using indicates that removal of the rotary cover may be necessary, but one of the bolts on the rotary cover is on the lower right corner of the engine and obstructed by the starter/ magneto housing.
How do I proceed or what specific tools would be helpful. Thanks, OliLt
remove the 4-13mm bolts, securing the intake manifold. The only one that will take some finessing is the one located closest to the mag housing on the bottom, but can be done.
I have the same problem any suggestions for a tool or socket that will fit in that tight space.
