JuliusCaesar
Is there any way to just remove the engine without removing the pump and driveshaft?  I need to rebuild my carbs and because these are impossible to pull out with a wrench OR pulling all 4 bolts off the rotary cover, i wanted to just lift it slightly so that i could get that last rotary cover bolt that is next level nuts to get at and pull it apart.  How anyone does this without the engine out is beyond me as it's so tight and everything if felt by hand (if you can even get that hand in there under the oil pump level arm.
thx
			thx
