Any input is appreciated..
I have a rebuilt 787 motor that hasnt ran. It turns strong but is not close to firing. I had to buy used carbs from someone for this motor but not sure if there is an internal problem with them.
So far I have done the following;
Checked compression..just under 150 psi in each cylinder
Verified spark for each cylinder
pulled carbs out/apart and cleaned..passageways clear..new fuel filters
If I push on accelaerator pump I see fuel spraying into each carb
Pulled rv cover and verified rv in right spot
Ive also tried putting a little fuel in the carbs and starting it
Ive tried a little fuel in the plug holes..
I may be overlooking something small so any ideas would be great
Thanks
Thanks
