brushmore
I posted this in the two storke boat section but had no luck and hoping someone over here might have an idea. I am two years into my Challenger 1800 restoration and have this one last hurtle. My starboard engine won't start. It starts turning over and the the starter disengages then spins. See my video below. The odd thing is that this doesn't happen with the spark plugs wires are disconnected.
This is the second starter and same issue with both starters. First was an aftermarket and then I switched to a rebuilt OEM. Battery is good since the port engine starts just fine. Tested the ground and it's good too. Also switched sparks plugs between the two engines so I know these are good.
Anyone seen anything like this before? Any other ideas for things to test?
