I know the oil lines are discussed ad nauseum, but I couldn't find an answer to my question when searching...
I have finished going over the fuel system on my 1998 GTS, with new fuel lines, emptying/cleaning the fuel tank, and installing a new carb. On start up she runs fine, both in and out of the water - thanks so much for the help on this forum!
Now, for the oil injection lines. I decided to do the fuel system first, then the oil. Just wanted to make sure that i got one solved before starting the other. The oil system works now, and I want to change the lines before I have issues. My question:
Can these lines be changed on a 717 with the engine in place? Can you get a crimping tool in there to get a good seal on the oil lines? I figure I will have to remove the carb, but that is not too bad to do - but the engine would be a new experience for me. Any help is appreciated!
