New to forum and pwc. 2nd year of 2007 4-Tec model. To start year changed oil and filter with no apparent problems. Started up for a few seconds before putting in water and seemed to run fine. Put in water, started fine, then quit.
I changed the the two fuel filters with no change(no small job).
How long can I safely run it out of water to test it? I have had it in the water 4 times now with same result of quitting. Won't start back in water once failed to continue running. Pull it out, let it set for a few minutes and will start back.
It kind of acts like fuel starvation like water in the gas(had that with lawn mowers), put in a couple of bottles of Heet to combat that possibility.
I read that there are trouble code readers out there? Is that affordable?
Your help is appreciated as the summer waits for no one.
Thanks
Thanks
