RideSeadoo
I have a 2017 300 RXTX and struggling with these two codes, P2081 and P0546. I believe i created the issue with putting the 90 degree short stack air filter kit on and with it ultimately rubbing/vibrating against the sensor plug. I put a new temp sensor on and then I started getting the code for a short to the 12 volt battery. The dealer shows the female sensor plug, but no part number. I keep on ordering the plug with pigtails on amazon, but so far none fit. Does anyone know a bosch part number or some direction to steer me in to find this plug and so I can replace it. I have seen the error code go away when I move the wires on the end of the plug. Also I have read that one can tighten the pins on the ecu. I have not taken the ecu off and would like a picture of these pins to tighten and maybe if you have the pin numbers for this model that I would tighten. Is there  a manual that i should get to further help me? I bought my ski used and it did not show up with the manual. Thank you for any help in advance.
