bought a used 2018 GTX 155 with 75 hours and paint is flaking off on the engine valve cover and back of the engine where the drive shaft attaches to. Called one of the repair shops and he mentioned it is because the carbon seal is bad and it is spraying water onto the engine. It will cost around $500 - $600 to have it replaced. There is also black line that accumulating around the hull in the same position as the seal which he says is sign of a bad seal.
I haven't noticed any cavitation or unusual amount of water in the bilge. Is there any way to visually tell if there is a problem with the seal? as far as i can tell, the ring seems to be intact.
