johnstan76
I have a 2015 Wake Pro 215 that ever since it flooded will not shut off. If you pull the main fuse it kills the machine, then once you put it back in, put key on post, it starts up and runs no issues but will not shut off when the key is removed from the post. The only way to shut it off is to remove the main fuse again. Another thing I have noticed is if you remove and replace the fuse with the key on the post the electrical starts up but the machine will not start, the ignition button is dead. Is it a bad Dess Post?
