M MX621 New Member May 11, 2015 #1 still ran fine all day. the CEL would go away then come back. can u read the diagnostic codes like on 4tec skis? or can only dealer read them? thanks
C cheappc Active Member May 11, 2015 #2 Should get the vtec tune map tool. Be careful and take it to the nearest dealer asap, you dont want anything really bad happening..
Coastiejoe Moderator Moderator May 11, 2015 #3 You do want to get the code pulled and solved. Being so new, I have to think you are covered. The longer you wait the worse it could be...
DGreen New Member Aug 12, 2015 #4 Same thing happened to mine. Turned out that the battery cable was loose and it was resetting the key. Took it to the dealer, the tech tightened the cable and no problem since.........its worth a shot!
C chuckthevoice New Member Aug 15, 2015 #5 You might have a loose battery cable. Tight the + and - Sent from my SGH-I337M using Tapatalk
