This is not my first post.
About 4 weeks ago, I decided to accidently flood out my engine in the driveway. Im sure your laughing!
Over about 10 hours, I got most of the water out through multiple floodings. I did not take it out to burn the water out but tried from the driveway. The next day, I took her out and noticed I could not go over 10mph. So, I changed the wear ring based on recommendations from here.
Yesterday, I took her out and got a P0524 error code, could not go over 3000rpm or 10mph. I brought her in and changed the oil. The oil was chaulk tan like I had some water in there. I cycled the oil again numerous times. Finally, I cleared the fault code for p0524.
Today, I took the boat out and hit 5000+rpm w a max speed of 20mph. However, the boat is still not picking up and takes minutes to get to 20mph. Also, that is the max speed with the throttle all the way down.
Did I not hook up the throttle cable correctly?
Could I have blown something or a gasket?
Is it time to bite the bullet and take it in?
FYI...I do not have a fault code.
Thanks for the Help? Sammy G
