Paddy@george
Please help. While riding the jet ski IBR light and check engine light came on. Found exhaust temperature sensor melted, melted water tubes. Replaced exhaust temperature sensor, replaced tubes on port rear side of ski that melted to exhaust. Drove jet ski everything worked, all lights off, no codes. Took out ski another day, iBR light and check engine light came back. Found water in ski. Found hose on starboard side going into the regulator had disconnected, reconnected hose, water no longer going into ski. Dried the ski out for 3 days. Start ski, IBR light comes back with check engine light. Codes that come on are: P1661, U16A5, U0401, U0129. Checked all of the forums. Found battery to have twisted/melted terminal on left side, checked for voltage, voltage good, replaced battery anyway. Cleaned all terminals. Checked all fuses, all fuses ok. Replaced for good measure. Turn ski on, same IBR light. Begin to check wiring. Shaking the main wiring harness will make the light go on. Checked wires at cluster, all seem ok. After moving wiring harness around IBR light went off. Put ski in IBR Override, able to manual raise and lower the bucket. Put in gear, give gas bucket goes up, in reverse bucket goes down, can also use VTS buttons to raise and lower the bucket. GO back to wire harness, shake it, IBR light back on and unable to go into Reverse or Neutral. Who knows what to check next? Is there a certain wire to be checking or a certain place to check for a failure. Do we think it is the IBR module if it operates correctly when light not on?
