NonCertified
Hello I am new to the forum, I bought a 2012 GTX and had to pull the motor to fix a lot of things. Now it won’t start after the rebuild. I get codes P0340 P0201 P0202 and P0203 for camshaft and injectors
It was running good before i pulled the motor. And I had to pull it because it overheated and Wasn’t holding coolant and had a bad oil leak. I removed The PTO cover, i replaced
water pump gasket,
oil pump gasket,
bearing for oil seal and inner seal,
along with the other oil pump parts in my kit.
Also inspected timing chain which looked fine.
I replaced the
drive shaft, (badly rusted)
new carbon ring kit,
new bellow, and bearing for shaft.
And Jet pump completely rebuilt,
I also noticed oil on my spark plugs so i went ahead and replaced the spark plug sleeves,
changed out all old fuses,
new rectifier,
and I replaced my cluster and married it to my ECU with a BUDS scanner..
it had power, I tried to start it but was clicking and wasn’t cranking, I tested my starter relay and it was bad. so i changed out my starter relay. Now she’s cranking, but now I get these codes. So I ordered new coils,
Spark plugs,
camshaft sensor,
and crank sensor.
first and only time I actually drove it is when i bought it and PO lied about all service history. Any helps appreciated
water pump gasket,
oil pump gasket,
I replaced the
new rectifier,
Spark plugs,
camshaft sensor,
and crank sensor.
