I've got a problem which the dealer calls normal. My new 2012 GTI 155 Ltd runs great, motor wise, but while accelerating from 10 mph to 30 mph my GTI leans to port about 10 or 12 degrees. After discussing this with the dealer, he states this is normal and nothing can be done. They tested it in-water twice and could not get it to lean over. I convinced him to let me go along while he tested it. I told the tech that it would not track in a straight line and that he had to pick a target on a distant shore and head for it. He returned and finally he said, "damn your right". He said it leaned from 10 to 30 mph and righted itself after 30. Still the dealer said it was normal operation. They tried another new GTI 155 and it did the same thing. I ride with an older bunch at 20 to 30 mph and it's not unusual to cover 40 or 50 miles per trip and i'd have to put up with the 12 degree list. We've checked everything on the hull and now I'm wondering if the GTI 130 has the same abnormality. I'm trying to get them to test one. Am I the only one that has this crazy problem..? Also my codes dumped twice within two weeks; it would not shift. Had to pull it out and trailer it four times to the dealer to re-install the codes and water test for listing I'm afraid to ride alone thinking it will happen again in the middle of the lake. Anyone having similar dumping problems..? Help me out. I need more hard info before going up against the dealer. He refused to give me any problem info from other customers. I can't believe Bombardier would market this hull knowing this problem existed.
