I have a speedster 150 2010. After I run the boat for about 15 or 20 min and the motor is hot when I go to start the boat it performs one rotation and then pauses for about 2 seconds and then finishes cranking over. If i open the motor cover and let the motor cool about 30 min it will crank normal again. Talking with a local tech they say there is no issue and i shouldn't be concerned. I have replaced solenoid, starter, battery and checked the charging system. I am running an Interstate deep cycle battery. Is this normal or should I be concerned? Any thoughts on what the issue might be? It certainly is heat related. I have attached a zip file with a video of the start.
View attachment SeaDooStart.zip
