2010 Seadoo Problems
Scarpa
I got a 2010 Seadoo GTX-is Limited 260. It got 0 hours on it, when the first time I'm starting it I notice the iBR light is ON and I think there must be something wrong with it.
After i start the engine everything looks normal, it started to creep forward like 2008 models. Well the 2010 should start in Neutral mode right.
Then suddenly I got error message, and I try to pull the brake lever and nothing happened. I pull again the lever and also pull the throttle lever a bit but still the craft only getting faster.
Then I take it back to the trailer and I got some fault codes :
UO129 or U0129
U 16A5
U 16A4
Also the iBR 30A fuse is fried, then I changed it 3 times and try to run the brake on land but all the fuse got fried also.
Can you guys give me suggestion what diagnostic should I make ? And what should I do now ?
It's a new ski, with 0 hours???
Hand it back to the dealer and tell him you want a different one. You shouldn't have to change a fuse on a new ski, and there should not be any error codes.
Sorry I couldn't give you a better answer... but they are passing you a lemon.
Yeah, I'm thinking of sending it back.. It's just it'll cost me another $500 for shipment here in my country ( 10 days using sea freight or 3 hours using plane with insane shipment fee )
So if the fix is just a simple fix then I would prefer to fix it.. So I thought if maybe any of you guys have had the same problem could chime in with a simple fix it would really help me alot..
Please, any of you guys out there know what that error code means ?
I couldn't find it in the net, there must be some definition and diagnostic step to do.
Here is the code again ( it's a U code )
UO129 or U0129
U 16A5
U 16A4
