I got a 2010 Seadoo GTX-is Limited 260. It got 0 hours on it, when the first time I'm starting it I notice the iBR light is ON and I think there must be something wrong with it.
After i start the engine everything looks normal, it started to creep forward like 2008 models. Well the 2010 should start in Neutral mode right.
Then suddenly I got error message, and I try to pull the brake lever and nothing happened. I pull again the lever and also pull the throttle lever a bit but still the craft only getting faster.
Then I take it back to the trailer and I got some fault codes :
UO129 or U0129
U 16A5
U 16A4
Also the iBR 30A fuse is fried, then I changed it 3 times and try to run the brake on land but all the fuse got fried also.
Can you guys give me suggestion what diagnostic should I make ? And what should I do now ?
UO129 or U0129
U 16A5
U 16A4
