Hi Guys, Today had some drama with my rxt, After putting in 1 litre of oil into the ski I went for a ride and noticed that the previous top speed of 108kph was down to 92kph so I had lost 10% of my speed, the revs also werent going over 7200 and the last 1000 or so revs werent increasing my speed, The fuel consumption also seemed to increase, however the engine sounded fine and there were no obvious leaks / smells / rattles .... I thought the problem might be a blocked intake grate as this has reduced my speed before, So i pulled into a ramp and had a check under, there was nothing visible protruding or blocking it that I could see, Then when I went to ride off the exhaust warning light came on for a few seconds with 1544 error code briefly, Then when I went to accelerate off the ski would only go a few kph, no matter how high the revs that would increase to, so I had full throttle range but acceleration only to a few kms, when I would rev it past 5000 the engine etc sounded fine and you could hear it trying but the ski would go only a touch quicker, it felt like I was towing a 2 tonne anchor, or the impellor was slipping or something between the engine and the impellor was slipping / failing to interface etc, I have given it a few hour break and tried again but its still not going any quicker ?? Would limp home mode allow it to rev that high but not allow it to actually go quick ?? Any ideas or suggestions are most appreciated
cheers ash
cheers ash
