So: after sitting for the past 3 weeks, I went to winterize my 08 215 Wake and it appears the starter has completely failed.
Time being what it is, it may have to wait til spring to be replaced. My question is; what do I need to do to safely prepare the ski for -40 degrees C without starting the engine? My thought is to use compressed air to blow out what water I can, then pinch the hose with the red band and run rv antifreeze through it with a drill pump, then blow this out with comp air. Will this work? Thanks!
