chamilton89
Who flashed your cluster? Candoo can't do it and not sure I would trust a dealer to do it out of the machine. It really needs to be installed in the ski, flashed using BUDS only and then married to your ECU. What you are describing is exactly what it will do if it did not get flashed properly. They do not come flashed from BRP. I think it is unlikely that your ECU is bad unless somebody tried to jump start it from a running vehicle.
The cluster was purchased directly from Candoo (who said that they could and that it was flashed). Once it was installed, I married it using my candoo pro. The cluster does seem to display correctly and shows no codes. The machine wants to start, but the starter stops just before it seems like it and immediately starts again.
What makes you think candoo didn't do the cluster flash? It would be fantastic is this was the issue! Seems like something a dealer could fix with a little software update.
