I have a 2005 sportster that cranks fine on the first crank, it might crank okay on the second, third and fourth, and then again it might not. Two beeps and it acts as though the motor is seized or the battery is low. Upon hooking a jumper pack or another battery to it, it still won't do anything right away, you generally have to wait a few minutes, then motor turns over like it is supposed to. Take the jumper battry off and motor will still turn over like it's supposed to. The problem then is you have to try cranking maybe 10 to 15 times to ever get her to fire off.
