Marshall_0
Okay, I have owned a pair of 2005 Sea Doo GTX 4-Tec 155's for about 8 years now. I keep them garaged and both PWC's have a little more than 100 hours on each. During the year when I am not using them I keep them on Battery Tender Juniors. (see attached photos) I have the PWC's serviced every spring at my local Sea Doo shop. They have always ran perfect for me and I have really tried to take good care of them. They have never even been jump started before, as I have seen in forums and posts that it can damage the MPEM when doing this.
This last trip I noticed that the fuel gauges where not working right in both of Sea Doos!
When the Sea Doo key is connected to the post I get a reading across the front LCD panel stating "Sensor Error" or something similar. I figured that it was a bad fuel sending unit as they both seemed to run fine, even though the fuel gauge was not working right.
After my trip I brought back my Sea Doos to the local shop where I get them serviced and asked them to fix the problem. I figured it was an easy fix. Buy new sending units and install, problem solved. A week later I received a call from my local repair shop. They advised me that the fuel gauge display issue was because the MPEM's were bad.
They also advised my that they could not fix the issue as this part (MPEM Part # 278002043) is no longer made for my Sea Doo and is not available.
This really blows my mind!
Let me get this straight.
A major company like Sea Doo that has 100 of thousands of these PWC's around the world stops making a vital electronic part that they can make good money on, in the repair market. Not only that, from what I can tell, there is no after market solution. The only solution I see is to buy a used MPEM for $950 each, which really has no warranty on it. This just seems plain crazy to me.
I have a few questions.
Has anyone else had this issue?
Could these battery tenders have cause the issue?
Has anyone came up with a workaround or fix?
From what I have read it seems to be fairly common for Sea Doos built from 2002 to 2007.
I am really surprised that there is not a aftermarket company making these MPEM's. After all doesnt MPEM stand for (Multi Purpose Electronic Module).
At this point someone needs to reverse engineer these MPEM's and sell them aftermarket. If I had the know how, I would take on this project!
