martinr1000d
Hello guys im here looking for direction. I purchased this RXT a few months ago and started learning its pitfalls quickly. I was an uneducated consumer and got the ski with a bad wear ring and impeller. So i replaced the wear ring and impeller then started adding some goodies. You can see these in my signature. With the wear ring and impeller i added an R&D anti cavitation cone and spacer and intake grate. Ski ran good about 64mph. Next came the pump trim wedge air intake and breather bottle. Ski ran about the same speed but i was not concerned. Well shortly thereafter since the bottom of the ski was a little rough (from a few beachings, rough ones at that) i had the gelcoat repaired. On the previous weekend I ran some WOT passes with varying fuel levels and loads up and down stream on calm water and was lucky to break 60mph! 61.5 mph to be exact. Bear in mind that with a bad wear ring, impeller and a hull that was rough as a cobb it ran 64mph. Also note that the ski seemed to "walk" from side to side in a manner that was somewhat unnerving. I dont think that I passed any debris throught the pump but cannot testify that the wear ring is still good, but i do know that on my performance lacking passes my rpm's were 8000-8050 MAX i do not recall ever seeing 8100 on the dig display. Thanks in advance for your help.
