Picking back up from last summer. Took ski out today and still running fine for about 15-20 minutes then dies and will immediately start back (even while still coming off plane). Any ideas? Coastie said might be Rectifier. Does this sound right? Hoping Coastie still around.
It is shuts off like the lanyard was pulled, then I doubt it is the rectifier. However, it is a simple test assuming you have an external rectifier. Simply unplug it. If the problem goes away, replace it. It will not charge when it is unplugged.
It sounds more like a loose connection. At the DESS or MPEM for example.
