Hi Guys, this site is very helpfull. keep up with the good work. Last weekend, after a 10 minutes ridding in saltwater with my Sea Doo it suddenly lost power and the engine cuts off. My Sea Doo has less than 25 hours on it. I tried to start the engine for about 10 times and it would not start (the starter works fine and the battery is good). I open the gas tank cover to avoid vacuum and also crack open the green bleeder valve on the gasoline line going to the carbursator to avoid high pressure, but it wouldn't start. After I trailed the Sea Doo back to the my garage, it suddenly started in the first attempt so I could flush the engine with fresh water. Any advice what this problem could be?
